Best Use and Purpose of a Concrete Roof
A concrete roof is among the most traditional forms of roofing. Concrete roofs were first used during the 19th century in Europe. Even today, landscapers vouch for the durability of concrete roofs, as they are known to last for many decades. Most of the contemporary concrete roofs are installed in the form of concrete roofing tiles that are easier-to-install.
Best Application of Concrete Roofs
Concrete roofs are recommended for homeowners who are searching for a roofing option that provides:
Greater Real Estate Value
Please note that the actual cost of new or replacement roofing is beyond the installation cost. The cost of roofing is largely determined by the kind of cost considerations it presents over a long period in the form of contributing towards the resale value or real estate value of the house.
Features of concrete roofs, such as fire resistance, add to the safety of the roof. However, this also contributes towards the financial evaluation of the house. In fact, the kind of roofing installed in a house is used to determine the insurance costs since greater fire resistance means less susceptibility to fire-related hazards.
Concrete is a naturally non-combustible material that makes the concrete roofing inherently immune against fire-related hazards. Some insurance firms even offer discounts to homes that have concrete roofing with standard fire-fighting certifications.
Concrete roofing in the house also provides a greater scope for the house being compatible with provincial building area codes. Again, this adds to the overall worth of the house at the time of re-sale. Thus, installing a concrete roof is a long-term investment for a homeowner.
Installation & Maintenance Cost Advantage
Concrete roofs installed in the form of tiles provide a considerable cost advantage over other roofing options. Firstly, concrete tiles are undemanding in terms of the manufacturing process, making them quite affordable. Furthermore, tiled roofing material can be easily sold in smaller denominations, preventing costs in the form of material wastage during installation.
Roofing installation can put forth considerable costs in the form of extra labor and material required to cover roofing surfaces wedged around demanding corners and angles. The use of concrete tiles for roofing ensures that such costs are saved since the tiles can be easily maneuvered. This is in stark contrast to other roofing materials that are retailed as sheaths or panels and entail greater wastage even if they are cut or molded.
Roofing tiles are easier-to-repair and maintain. They can be easily replaced without the need for professional assistance—a major cost-saver. Concrete surfaces are also easier-to-paint and stain than other roofing choices.
Durability & Safety for Residential Purposes
Concrete roofing material is prepared from materials like sand, cement and selective pigment. Concrete roofing tiles are more resistant to common roofing issues like moisture-induced deterioration and chemical corrosion. Concrete roofs don’t rust or corrode, as they are chemically inert, i.e. they don’t react when exposed to chemical vapors.
When using asphalt shingles, weight-based calculations are necessary to ensure that the roofing is compatible with the weight-bearing capacity of the walls/columns—a concrete roof can be installed without such apprehensions.
For executing basic repairs, the concrete surface is safer since the concrete surface is largely non-slippery as compared to wood or metal roofs.
Energy Efficient & Eco-friendly Performance
Concrete roofing is prepared from easily-available raw materials that don’t need further processing using chemical treatments. In terms of green performance, concrete roofs are among the most preferred roofing option. This is also because they don’t add to common environmental issues like adding to the landfill sites.
Unlike shingles that cannot be recycled in an eco-friendly way, even the debris of a damaged concrete roof can be recycled and used for making basement filling material.
