Best Uses for a Floating Engineered Wood Floor
A lot of individuals find a floating engineered wood floor ideal in providing more warmth, sophistication and comfortable atmosphere to the house. However, it is not suited for places that climatic changes are normal. In areas that are normally damp, hardwood can show negative effects. Thus, if you want to invest in a good quality of flooring without being affected by environmental changes, make sure that the material used is of the best kind. An ideal suggestion for this would be engineered wood flooring.
Durability
This type of flooring is made up of fiberboard that can counteract the effects of dampness on the wood. This can also allow the boards to expand. This can best be installed in basements since it can withstand higher levels of humidity. When you use real wood, this will also serve as an added decoration to the dull atmosphere in your house.
Easy Installing
Aside from the durability of this product, you can actually install it in any room of your choice. You can even do it alone without compromising the quality of the item. There is no need for you to use nails just to attach boards to the subfloor. The only thing that you have to secure is your subfloor, which should always be dry and clean. Once you have successfully done this, you will notice the incredible results later on.
Security
Most of these engineered hardwood floorings are equipped with locking systems for a more secured surface. You can see that there are no small gaps in between. Again, you will see the versatility as well as the practicality of the item here. When you opt for floating floor, you can bring it along with you whenever you move into a new house. But if you wanted it to be totally new, you can easily replace it without going through a tedious installation procedure. Make sure that you consult a reliable contractor to be guided accordingly in your shopping.
Dual Features
Lastly, installing engineered wood flooring will allow you to use it even in places that are prone to the destruction of solid hardwood floors. It adds value to the home, as well as promotes organic ambiance to the entire house. One of the notable benefits you can get out of this type of flooring is the dual features. Aside from the fascinating design of its outer layer, it is also made to perfectly suit with climatic changes. This is ideal in a summer house or property that is not directly driven by environment factors. The good thing about this is it is cheap compared to other solid hardwood alternatives. Hence, this can be a favorable option when you are on a tight budget.
