Login Error
Close
Bevel Siding
by DoItYourself Staff
A type of finished siding used on the exterior of a house is a bevel siding. It is usually manufactured by re-sawing a dry, squared, surfaced board diagonally to produce two wedge shaped pieces.
There is a variety of patterns and colors that the bevel siding can be. You can look around at different places to see the variety that is out there for you to choose from for your home. The bevel siding edge gives an attractive shadow line. Both faces are saw textured.
Different Shades and Types of Bevel Siding
You can get a cedar bevel siding or, if you don't like that look, you might like the redwood bevel siding. If you’re more into white, then check out the white fir bevel siding. You can look around until you find the perfect bevel siding that you want for your home. The prices for each type of bevel siding differs at different companies so do your research and find the best price for your budget.
 forum activity
