Bi-Fold Shower Door Installation
A bi-fold shower door is the most preferred option for shower doors in modern times. They give a contemporary look and are beneficial in many ways too. Installing the bi-fold shower door is not a herculean task. It is an easy task that can be accomplished in a short span of time.
Step 1 - Remove Existing Door
This is first step to install a bi-fold shower door. Many people do this towards the end with makes the process inconvenient and clumsy. Hence, make sure to remove the existing door before proceeding further.
Step 2 - Erect the Door
The next step is to decipher the top part of the new door and erect it such that the top part faces the ceiling. You will need to locate the holes close to the door hinge at the top part of the door.
Step 3 - Insert Pins
Take the smooth pin that came in with the hardware kit and insert it in this hole. You also have to insert the roller pin on the second hole at the top. The last pin left out is the ridged pin that has to go inside the hole that is closest to the door frame.
Step 4 - Fix to the Door Frame
Now, with all the pins in place, you will have to erect the door and screw it into the door frame using the screws provided. You will have to install the end spring in the guide farthest from the hinge so that the door can swing with ease. Once this is done, the door is ready for use.
