Login Error
Close
Blu Ray Player: 7 Things to Know
by DoItYourself Staff
Before purchasing a Blu-ray player, there are 7 things you should consider. The problem with standard DVDs is that they lack high-definition playback and recording capabilities. A Blu-ray player utilizes laser and video compression technology to output a crisp, high definition image.
Can a Blu-ray DVD Player Read a Standard DVD?
Yes, Blu-ray players can read a standard DVD. A Blu-ray player will allow the DVD disk to be viewed at standard resolution or have the player upgrade the signal to match 720p / 1080i or 1080p modes.
Do you Need an HDTV to Get the Blu-ray High Resolution?
Blu-ray players can be connected to a TV that has composite video inputs. However, the only way to achieve the high definition is through an HDMI video connection.
Can a Blu-ray Player Read Music CDs?
Most Blu-ray players will read CD / CD-R / CD-RW disc. Some Sony and Pioneer first generation players will not recognize CD’s. If you want this feature be sure to check out the specifications before you purchase one.
Do Blu-ray Players Support the New audio Format?
Blu-ray manufacturers are not required to support newer formats such as Dolby True HD, DTS-HD High Resolution and DTS-HD Master Audio which are optional. However, all Blu-ray players support Dolby Digital, DTS and PCM. If you want to enjoy the greater resolution detail read the specifications to make sure your player supports these audio formats.
What Type of Connections are Available for a Blu-ray Player?
A Blu-ray player has similar connections as a DVD player. The connections include composite, S-Video, analogue stereo, digital optical and coaxial audio outputs. Blu-ray players come equipped with a High-Definition Multimedia Interface (HDMI) port that transports audio and video over a single cable. HDMI provides maximum video resolution and audio formats including Dolby TrueHD and DTS-HD Master Audio.
Is an Upgrade to Blu-ray Worth the Price?
Blu-ray players can range from $120 to $5000 depending on what your budget is and what you are looking for. A Blu-ray player is worth the upgrade for an HDTV or a home theater system.
Are There Any Extra Features?
Some Blu-ray players can incorporate multimedia streaming from Netflix, YouTube and Pandora. Some manufacturers include apps that can display news and weather updates on your HDTV. In addition, some Blu-rays can interface with PlayStation games.
 forum activity
