Boat Hull Designs: Understand the Differences
The boat hull design is one of the most important considerations when choosing a boat. Apart from the fact that the hull serves as the main structure of the boat or ship, it can also directly affect the overall performance of the water vessel and even set the manner in which it can be used. Below are the most common hull designs that you can choose from when you are in the market for the perfect boat.
1. Round Bilge Hull
This is the most widely used type of hull design today mainly because it allows the boat to sail more efficiently. A boat with a round bilge hull will have better planing, which means the hull can be lifted higher above the water surface and therefore reduce drag. When that happens, a boat will sail faster or consume less fuel. For this reason, this type of hull is also popular for boats or ships that are intended for long voyages.
Moreover, round bilge hulls can be made in various lengths. So, regardless of the size of the boat that you want, you can have this type of hull design. When in use, this hull structure can also help disperse sea spray away from the boat’s topside. The only downside is that round bilge hulls can take a long time to build.
2. S-Bottom Boat Hull
The bottom part of this hull stretches smoothly to the keel and is formed like a big S, hence the name of the design. The absence of sharp corners on this type of hull allows the boat to sail more comfortably as it minimizes the tendency of the boat to roll while on water.
3. Flat Bottom Boat
Flat bottoms are cheaper to build compared to most other types of boat hulls. The reason for this is that they are relatively easy to construct. Since the hull structure is flat, the bottom part of the boat does not go deeply beyond the waterline, meaning the draft or draught of the water vessel is shallow. On the plus side, a shallow draft can allow a boat to run at high speed. However, the same characteristic can cause a very bumpy boat ride. Also, a flat boat hull lacks stability, hence the boat crew and contents must be carefully balanced while sailing. This type of hull is ideal only for use in calm waters.
4. V-Bottom Boat Hull
Unlike the smooth S-bottom hull, the V-bottom design has a sharp run to the keel. This provides the boat a deeper draft and better stability. If you want your boat to have a very comfortable ride, choose this hull design. The only drawback is that a V-bottom boat can consume more fuel as it will need more power to sail.
5. Multi-Hull Boat Design
Some boats have more than one hull. The main advantage of this design is the fact that it distributes the weight or the center of gravity of the water vessel. By doing so, the boat’s drag is significantly minimized. For this reason, modern leisure, sports and even transport boats that need to travel fast have this hull design. Pontoon boats and catamarans are the best examples of multi-hulled water vessels.
