Login Error
Close
Boiled Linseed Oil vs Raw Linseed Oil
by DoItYourself Staff
Using linseed oil is a great way to polish or finish off your furniture; however, you should be knowledgeable of the difference between boiled linseed oil and raw linseed oil. Read on to learn about how these two types of oil work differently.
Raw Linseed Oil
Raw linseed oil is literally squeezed oil produced from flax seeds. The oil gathered from this process is packaged and sold without any chemicals, solutions or additives to preserve it.
Raw linseed oil is known to have a very slow drying time. This can be a good thing, as slow drying time enables paint to completely level and set properly. Raw linseed oil should be used for equipment that is frequently exposed to exterior factors, such as the weather.
Boiled Linseed Oil
Boiled linseed oil goes through a process that alters the drying qualities of the oil and makes it dry more quickly. It is better to use on furniture or tools that need preserving. It is also used as a wood finish, and it can be used as it is or mixed with other solutions or other oil bases. When mixed with other solutions or oil bases, boiled linseed oil provides a better gloss and makes the item more durable.
 forum activity
