cancel
Job type :
Zip Code :
community forums
comments
Brick Fireplace Design for Contemporary Living Rooms
Creating a new brick fireplace design is a great way to change the look of your living room without spending a lot of money.  There are several different types of brick in all sorts of colors to customize your design to your specific tastes.
Using Different Course Patterns
Installing a soldier course or using keystones are a great way to enhance your brick fireplace design and give your living room a classic and stately look.  The contrasting mortar joints and focal points of these design patterns provide a handsome accent to the brick design.
The Benefits of Accent Colors
Incorporating accent strips using contrasting color bricks are one way to break up the monotony of a standard brick wall.  For example, inserting a dark brown accent strip in a light tan brick wall will give the wall a warm and attractive look.  You can even insert accent bricks in random locations if installing an accent strip is a little too uniform.
member comments
Related Articles
Chimney FiresChimney Fires
What you should know about chimney fires, how to avoid them, and what to do... read more
Top Ten Benefits of Ceramic Tile
Ten reasons why ceramic tile makes for great floors... read more
Heating Wood Stoves
Heating wood stoves provide an alternative to fireplaces and other heating options. Similar in design... read more
articles we like
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Why is Christmas celebrated on December 25?
This article has creative christmas decorations you can make using Christmas tree balls... read more
You Can Get Your Cat to Use a Scratching PostYou Can Get Your Cat to Use a Scratching Post
Clawing comes naturally to cats for a number of reasons: it helps them mark territory,... read more
sponsored articles of the day
diy centers
