Brick Paving Patterns
If you're interested in paving your deck, patio, driveway or any other part of your home using brick paving patterns, there are a variety of unique patterns from which you can choose. When shopping around for brick paving patterns, it is important that you familiarize yourself with the various types of patterns in order to ensure that you select one that perfectly suits the area you wish to pave. This article will help narrow your choices by exploring the four most popular types of patterns.
Stretcher Bond
Stretcher bond is the most popular type of brick paving pattern--perhaps due in part to it being the easiest to install. The bricks appear in a side-by-side fashion and can be stretched out to accommodate wider areas. The stretcher bond pattern is commonly used to pave decks and walkways. This pattern is also known for giving paved areas a simple but very modern look. In addition, the stretcher bond pattern meshes nicely with virtually any home, old or recently built. The one downside to stretcher bond is that many people find it drab and uninspired.
Herringbone
The herringbone pattern is unique in that it comes in two types--45 degree patterns and 90 degree patterns. This pattern makes use of small, rectangular bricks and is typically used to pave large ares. Whereas the 45 degree pattern is generally used to pave patios, its 90 degree counterpart is used almost exclusively in swimming pools. While the herringbone pattern remains a common brick paving pattern for pool owners, it is quickly falling out of style with people looking to pave patios, as it gives off a distinct 1970s feel.
Basket Weave
The basket weave pattern, as its name suggests, features bricks that resemble baskets being woven. This pattern is popular for older homes and, as such, doesn't mesh very well with newer ones. If you own an older home and want to give your patio, driveway or walkway an authentic look, basket weave is the pattern for you. However, if your house was built within the last half-century, you'd do well to find another pattern.
Randomly Mixed
If you own a newer home and are looking to give your paved areas a hip, modern feel, you may want to consider a randomly mixed pattern. This type of pattern, as you can probably guess, is a mishmash of different shapes of bricks. Although this pattern is relatively new compared to the rest, it is fast becoming a favorite among first time homeowners and is perhaps the most unique brick paving pattern currently available. It should be noted, however, that a randomly mixed pattern is an absolute no-no for older homes.
And there you have it. Whether you're looking to pave the walkway of a brand new house or you just want to touch up an old patio, you have all the information required to select the perfect brick pattern for your home.
