Login Error
Close
Brick Siding: Advantages And Disadvantages
by DoItYourself Staff
Brick siding enhances the look of your home while being a durable building element. The brick siding systems are designed to reduce cost and are easier to install. There are some advantages as well as disadvantages to using brick siding.
Advantages of Brick Siding
The biggest advantage of brick siding is that its low maintenance. Once installed, brick siding can last for a very long time. There is no need to paint or perform other upkeep tasks associated with wood or vinyl siding.
Brick comes in a variety of colors and is durable, making it a load bearing building material. Brick siding withstands heat and offers better fire protection than wood and vinyl siding.  It also provides a sound barrier, keeping noise outside.
Disadvantages of Brick
Brick siding may be more difficult to repair when it becomes damaged. This is especially true for brick siding that is part of a wall system where the individual brick may not be easy to replace without having to remove the entire wall section.
Because brick is made from organic material it is important to keep moisture from seeping into the brick siding. Moisture build-up over time causes brick to crumble and become brittle. Organic brick subject to prolonged exposure to water will become discolored and fade over time.
 forum activity
