Login Error
Close
Brick Tile Flooring
by DoItYourself Staff
Brick tile is quickly becoming one of the most popular flooring options in the market today. The old-world look that it presents you with is unmatched in the industry. While brick has been used as a flooring option for centuries, this new generation of brick tile presents a great option for those in today's high-paced world. Here are a few things to consider about brick tile and what it can offer you.
Design
One of the big benefits of using brick tile is the look that it gives you. With brick tile, you get an actual brick look on the floor of your home. You can get it in a variety of different colors and sizes. Most of them are less than an inch thick and they look just like a real brick. With brick tiles, you can customize a pattern as well. You could do a standard square pattern or an alternating brick lay. You could even do a herringbone pattern with the tile if you wanted. With brick tile as the floor, you are free to do a number of different design themes in the room as well. Your options are pretty much limitless.
Cost
The cost of brick tile is going to be very similar to what you can find with ceramic or porcelain tile. In fact, some of the brick tiles out there are actually made out of porcelain to be a little more durable. However, you will still find some that are made out of clay and the traditional brick materials. On average, you should be able to find some nice brick tiles for between $5 and $15 per square foot. The more expensive tiles you find will usually be the most durable with the longest warranty. They will also tend to look a little more realistic with the most character.
Installation
With the installation procedures of brick tile, you should be able to turn this into a do-it-yourself project if you feel comfortable with it. It is installed in the same manner as a ceramic or porcelain tile. You have to install it on top of a solid surface like concrete or concrete board. Then it is adhered to the floor with thinset or tile adhesive. If you are comfortable installing tile, then there is no reason that you could not also install brick tiles.
Care
After the brick tile is installed, you will most likely want to seal it with a tile sealer. Brick tile is a little porous and therefore, could absorb liquids if it is not properly sealed. Sealing the grout in between the tiles is also advisable so that it does not stain.
You should be able to clean the brick tile with any number of tile cleaners that are available in the market. You can add these cleaners to a bucket of water and mop the floor with it. Use a dust mop for routine cleaning and mopping for deep cleaning.
 forum activity
