Repairing a pantry storage cabinet yourself can save you money, time and trouble.
Step 1 – Determine if the Break is Structural or Cosmetic
If a break is cosmetic, it only affects the appearance of the cabinet. If the break or crack is at a place where there is work to be done—like at a hinge or latch—then the break is considered structural. Handle such repairs carefully so the finished product will be both functional and durable.
As far as the repair goes, if the break is structural, worry less about matching seams and finishes and instead, make sure the screws, pins or shims are properly in place.
Step 2 – Cut Out the Broken Piece
If you choose the replacement method, use a jig saw to smoothly cut a piece with straight edges out the the old cabinet.
If you have a piece of wood that matches the old wood—like an old cabinet door, an extra shelf, etc.—cut the repair patch from that piece of wood. If not, choose a piece of wood that has a similar grain and can be finished to closely match.
Step 3 – Cut a Replacement Piece
Using the measurements of the space you just cut, cut a new piece that will fit into that area.
If it is a structural break, you will need to use a variety of fasteners to get the piece to stay. Purchase wood dowels and a drill bit with the same diameter. Drill guide holes in the cabinet that is left, then drill holes into the repair piece. Glue both sides of the dowel, and insert it into the repair piece.
Spread wood glue along all the edges of the piece, and then put glue on the other end of the dowels. Clamp the piece into place and let it sit for several days. With care and time, the piece should hold and be functional.
Step 4 – Smooth and Finish
Once the frame is in place, you can fill, paint or finish it to match the current cabinet. Try to do artistic work on the finish so that it blends in as well as possible.
Step 5 – Consider Alternatives
If the inserted piece doesn't quite work, try an epoxy wood repair kit. These kits are more effective than they appear and offer a strong bond that can last longer than wood. Additionally, the epoxy wood repair is a waterproof substance, so if water contributed to the original damage, you will have one less thing to worry about.
Questions of a Do It Yourself nature should be submitted to our
