Login Error
Close
Budgeting Home Security Surveillance Systems
by DoItYourself Staff
Home security surveillance systems offer additional protection when used with an alarm system. Money is saved when assembly and installation is done by the homeowner.
Reasons for Home Security Surveillance Systems
  • Decrease your chances of burglary by using a home security surveillance system.
  • In case of robbery you have the ability to identify and catch the thief or thieves.
  • Home security surveillance systems provide added protection to the neighborhood.
Questions to Consider
  • How much money do you want to spend on a home security surveillance system?
  • What kind of security camera is best for your home?
  • What are your security priorities?
  • How big are your home and the size of the area you want watched?
  • Do you want a wired or wireless surveillance system?
Types
You can use either a wired or wireless home security surveillance system. A wired system is more costly and you may want to hire a professional to install it. Wireless home security systems are easily put together and are affordable.
What's Included
  • Video Cameras
  • Recording device
  • Monitor
  • Motion detectors
Covert or Overt Systems
Home security surveillance systems come with cameras and you can decide if you want to use covert or overt cameras. Covet systems keep everything hidden. Usually a covert system is used for watching the activities of people that work in and around your home. Overt systems are visibly placed. Theses cameras can deter thieves from entering your premises. The cameras are available in dome, bullet and infrared. Bullet cameras are the most common because they are good for inside and outside. They are small and weather resistant. Cameras with infrared are the most expensive but they are capable of working in both the daytime and the nighttime. They can also operate inside or outside.
Recording Cost Options
Using a Video cassette recorder (VCR) is a cheap way to record your camera surveillance video. Surveillance software and hardware gives you another way to record and view your video inexpensively. Not only can you record with this system but you can also view it through the internet on your computer, laptop or personal digital assistant (PDA). A DVR card is and affordable option. It is installed into the peripheral component interconnect (PCI) in a personal computer (PC). Video with this system is viewed anywhere. The most expensive system is the Digital video recorder. You can view the video on a television or computer monitor.
Monitors
The kind of monitor you need depends on what type of home security surveillance system you decide to use. The two types of monitors used are TV and computer screen.
Motion Detectors
Motion detectors are the most costly feature in a surveillance system. However, they allow the camera to record only when it is triggered by motion which saves on recording space and the time it takes to view the video.
 forum activity
