Login Error
Close
Build a Bike Shed in 6 Steps
by DoItYourself Staff
what you'll need
  • (4) 6-inch by 8-inch by 10-foot long pieces of lumber; all-weather
  • (1) 5-foot by 10-foot by 3/4-inch thick piece of plywood; all-weather
  • (1) 4-foot by 8-foot by 1/2-inch thick piece of plywood; all-weather
  • (7) 2-inch by 4-inch by 10-foot pieces of lumber; all-weather
  • Measuring Tape
  • Pencil
  • Saw
  • Nails
  • Hammer
  • Sheets of Tin
  • Carpenter Ruler
  • Penny Nails
A bike shed can protect an avid cyclist's investment and give a place for the children to store and work on their dirty bikes. The steps that follow will show you how to build a simple bike shed that measures 5-foot by 10-foot.
Step 1 - Building Area
Pick an area that suits the size of the bike shed you are building. First, look for a patch of land that is level and sturdy. Next, clear the area of rocks and debris. If there is a bad slope, use brick or wood to make the area even.
Step 2 - Trimming the Wood
With the area prepared, you can begin cutting the wood for the project. First, leave two of the 6-inch by 8-inch pieces of lumber 10-foot long but cut the others to 4-foot long pieces.
Step 3 - Bike Shed Frame
The floor will sit on the frame and it is easy to build. First, arrange the frame by placing two of the 4-foot long pieces of lumber you just cut between the two 10-foot pieces of lumber. Next, evenly space out the remaining 4-foot long pieces in the frame and between the other two you have in place. Now, use the carpenter ruler to make sure the frame is even and forms a rectangle. Finally, nail the frame together using penny nails.
Step 4 - Adding the Floor
Now that the frame is built the bike shed will begin to take shape. First, place the 5-foot by 10-foot piece of plywood on top of the frame. Next, make sure the plywood lines up evenly with the frame. Finally, nail the plywood in place.
Step 5 - Creating the Walls
The bike shed is open on one side for easy access so you only have three walls. First, decide which of the long sides of the shed will be used as your opening. Next, nail two 2-inch by 4-inch by 10-foot pieces of lumber to the frame on the short sides; flat sides down. Now, nail four 2-inch by 4-inch by 10-foot pieces of lumber to the back of the frame; flat sides down. Next, nail the remaining plywood sheets (cut to fit) to the sides. Finally, nail the walls to each other in the corners.
Step 6 - Tin Roof
The final step involves putting on a roof. First, trim the piece of tin to fit the dimensions of the bike shed with an inch overhang on all sides. Next, place the tin roof on top of the bike shed and make it as centered as possible with the opening getting a 2-inch overhang. Finally, nail the tin roof in place to finish the project.
At this point you can add sealant and other water-proofing materials then paint the bike shed or stain it.
 forum activity
