cancel
Job type :
Zip Code :
community forums
comments
Build A Mortarless Retaining Stone Wall
A retaining wall can add curb appeal and value to your home. By carefully following these steps, you can make your own beautiful stone wall that will last for decades.
Tools and Materials:
  • Stones
  • Flat-nose shovel
  • Garden spade
  • String level and stakes
  • Carpenter’s level
  • Hand tamper
Step 1-Design the Wall
Plan, plan, plan! Measure the area, make a sketch. Consider any openings or curves. Lay a hose to test your layout. Keep in mind that you may have to check with your local municipality before building a mortarless wall, although often you don’t need approvals for walls under three feet high.
Step 2-Choose the Stones
Whether you want the wall to look layered or random, you will want each stone to have a generally flat “top” and “bottom” so they stack well. Get a variety of sizes so you have some large flat ones for the bottom row and the top row or “cap.”  The rest of the stones can either be of similar size or varying sizes, depending on the look you want.
Step 3-Calculate
Bring your wall measurements and sketches to the stoneyard so a stonecutter can help you calculate how many stones you need.
Step 4-Lay Out the Wall and Trench
Lay out the wall contour with hose, string, etc. Dig a trench deep enough for at least half the stone’s height. The first course needs to be a firm foundation for the following rows; the rule of thumb is the depth of the base of a stone wall should be half the wall’s height.  So for a 3 foot wall the base should be 18 inch deep. Get the trench as level as possible, and sweep away any loose dirt so your first course has the most solid footing it can have.
Carve away the slope behind the trench so you will have space to work.  You’ll use this soil to fill back in as you go.
Step 5-Lay Out the Stones
Lay some of your largest, widest stones first to make a solid base for the wall. The stones should be generally level with the horizon and with each other. They should also fit together snugly. Fill the excavated slope back in after this row (and after every row), using soil and small stones. Tamp the fill to “cement” the stones in place.
Step 6-Place Second Stone Layer
Lay the next course, whether it’s random or layered, so that the stones are staggered. Avoid having spaces directly above one another. Make sure you “step back” each succeeding row slightly so that the wall leans back into the slope.
Step 7-Reverse Stones
Continue laying courses, fitting the stones as you go and aiming for the greatest stability possible. When the wall is half its total height, for the next course add occasional stones laid the long way rather than the wide way so that they are set into the dirt of the slope. These “deadmen” will improve the integrity of the wall with the slope. The guideline on deadmen is one per 16 feet of wall face.
Step 8-Lay Flat Stones
Finish the wall with another row of large flat stones to serve as the top or “cap” of the wall. The more substantial these stones are, the better they anchor the wall.
Step 9-Landscape
To further integrate the wall, plant ground cover, flowers or vines behind and in the spaces of the wall. The roots, as they grow, tie the soil together.
member comments
Related Articles
Planning the Perfect Deck
Here are some basic planning, design and building tips for the deck of your dreams... read more
Real vs Artificial Garden Rock: 5 Projects
When you want to build water projects in your garden, a rock walk, or to... read more
How to Choose a Pond Kit When Building a Backyard Water Garden Pond
Whether you are a first-time pond builder or just prefer the convenience and cost-effectiveness of... read more
articles we like
Office Chair
The office chair, or desk chair is a familiar and constantly used part of the... read more
Transom Window
A transom window is a common feature in modern homes. The window rests over the... read more
Stop snoring -- live longerStop snoring -- live longer
Do you wake up fatigued because your snoring doesn't allow for a deep, good night's... read more
sponsored articles of the day
diy centers
