Login Error
Close
Build A Shower Stall In 10 Steps
by DoItYourself Staff
what you'll need
  • Prefabricated Shower or Shower Surround
  • Tape Measure
  • Hole Saw
  • Adhesive
  • Caulk (Silicone)
  • Electric Drill
  • Plumber's Tape
  • Screws
  • Blue Tape
  • Pencil
  • Plumb Level
  • Shower Fixtures
You can build a shower stall in a few steps if you have the right tools and the necessary know-how. Here's a quick guide to building a shower stall in your home.
Step 1-Select Style
Choose the type or style of shower stall that you want. Make sure you pick a style that works well with the space that you have. If you have a large bathroom, you might consider installing a shower stall intended for two people.
Step 2-Consult Plumber
Nothing dictates that you cannot do the plumbing your own self when installing a shower, but what you are going to want to do is be prepared to consult a plumber with questions. The better prepared you are, the better the process will go.
Step 3-Prepare Area
Prepare the area by installing needed flooring material or doing anything else that needs to be done before the new shower stall is installed. If you do this all beforehand, it will help greatly.
Step 4-Read Instructions
This is a vitally important step, because knowing what steps need to be taken will ensure that you properly install your shower stall.
Step 5-Begin Installation
Begin by installing the shower pan, putting it on the subfloor or concrete over the drain with a shower adhesive. Install the first panel using shower adhesive on all sides and corners of the non shiny side.
Step 6-Measure Mixing Valve
Measure the mixing valve's center to guide you in drilling holes for the shower fixtures.
Step 7-Install Remaining Panels
Install the shower panel where the fixtures will inserted, the same way that the first panel was installed. Then install the remaining panels if there are more than two sides to your shower.
Step 8-Install Plates
Install the base plates that will accommodate the glass enclosure, using blue tape to hold them together while you drill the holes and secure everything into its place.
Step 9-Finish It Off
Place the side plates and the glass panel enclosures into their places. Add rubber piping to ensure that the entire enclosure is completely water tight. Finish off the top by adding the top plates to the shower stall, using silicone caulking to keep the glass seams completely water tight.
Step 10-Install Fixtures
Add in the shower fixtures, including control knobs and shower head as soon as all of the caulking and adhesives have set up completely. Prevent leakage with plumber's tape on the shower head. Make sure that there is no leakage before using your newly installed shower.
 forum activity
