Building a Floating Floor on an Uneven Surface
A floating floor can really spice up any kind of home design. Some even serve multi-purposes such as a small stage for live performances and the likes. However the floor will be used, it is necessary that the area where the floating floor would be installed first be inspected.
Ideal Locations for Floating Floors
Ideally, a floating floor must be installed in a sturdy and even space. If this is not the case in your set-up, you should search for ways to improve the location of your floating floor.
Preparations in Correcting Uneven Surfaces for Floating Floor
Decide on the space where you would be putting up your floating floor. If you are considering using wood, make sure that the area you would choose would be safe for such materials. As such, laying a wooden floating floor on soil would need more considerations to ensure the protection of the wood.
Measure the area to ascertain what materials you would be using. If you are laying floating floor on the ground, considering having dips filled up with soil. You could also have rising areas plowed prior to the installation of your floating floor.
Sanding and Filling
For concrete and other similar subfloors or grounds, it might be best to allot a budget for sanding and filling. Get a level to determine the areas which you need to level. Evenly sand those areas that are a lot higher than the rest of the surface. Dust off all debris before measuring it up using your level. For dips, get concrete putty or other similar filler. Apply this to areas that need fillings. Let it dry completely before measuring it again. Sand the fills that has risen to more than the desire level.
Installing a floating floor on an uneven surface could also be achieved by skipping all the above-mentioned steps. However, the task at hand would be trickier. Thoroughly clean the area where you would be building the floating floor. After that, measure the areas where there are depressions and rises. The “legs” of your floating floor should be made to fit such sections.
In this regard, you need to measure up each of the fills and rise to be able to adjust the sizes of your floating floor’s legs. Measuring and wood cutting are the most important steps here. Any miscalculation could lead you to the misfit of the floating floor’s legs to the surface. Also, remember that the materials you would be using for the floating floor’s legs should be the sturdiest. These parts are like foundations that would be tasked to carry most of the pressure to the floating floor.
After all the adjustments have been done, continue on attaching the floor boards of your floating floor. Drive down nails and screws next to each other to stop the boards from squeaking. Also, double check for surface impurities that would need sanding. Hammer down each nail to ensure that they don’t come loose. Apply varnish and paint as desired.
