Building a Futon Bunk Bed
what you'll need
- 4 - 4x4 posts, 6 feet long
- 2 - 2x6 boards, 7 feet long
- 2 - 2x6 boards, 4 feet long
- 2 - 1/2 inch plywood sheets, 39 inches by 75 inches
- 2 -2x4 boards, 6 feet long
- 6 - 1x4 boards, 15 inches long
- Lag bolts, washers, nuts
- Wood Screws
- Adjustable wrench
- Drill
- 3/8-inch Drill bit
- Pencil
- Crosscut handsaw, or circular saw
- Primer
- Sandpaper
- Paint or stain
With the popularity of bunk beds and futons in family homes with children, what could be more practical for parents and fun for their children than a futon bunk bed? As a do-it-yourself handy man who would like the idea of putting one of these combination beds into one of your children's bedrooms, you can easily make one that will give you a bed or couch with a second bed above it. Just follow the 5 steps below.
Step 1 – Make Preparations
To build your futon-bunk bed, you will need to begin with 2 futon sets and the lumber to make your bunk bed frame. Determine the dimensions of the headboard, foot boards, sideboards, and posts you plan to use for your frame. Then cut them to match the dimensions you've created.
Step 2 – Construct Your Bunk Bed Frame
Build your bunk bed frame using the lumber you've measured and cut. Drill holes in the 4x4 posts for the bolts that will connect the headboard, foot boards, and sideboards to the posts. Then, attach these pieces using lag bolts, washers, and nuts.
Step 3 - Attach Futon and Bunk Bed Frame
Into the bunk bed headboards and foot boards, drill holes large enough so that you will be able to insert through them the lag bolts that came with the futons frames.
Attach futon frames to the bunk bed frame using the appropriate sized bolts and nuts. If you use bolts that came with the futon and if they are the wrong size, you may need to replace them with new bolts that fit the bunk bed post holes. When you've inserted all necessary bolts, washers, and nuts, tighten the nuts with a wrench to keep the frames solid.
Step 4 – Build a Bunk Bed Ladder
With the 1-inch boards and the 2-inch boards, build a ladder 6 feet high and 15 inches wide. Attach the ladder to the sideboard of the top bunk near the foot of the bunk, or to the top bunk's foot board where it will not interfere with anyone getting into the bottom bunk. Attach the ladder with metal brackets or by attaching one end of a 1-inch board to the top bunk frame and the other end to the top of the ladder
Step 5 –Finishing the Bunk Bed Frame and Ladder
When you have your futon, bunk bed frame, and ladder solidly attached, sand the ends of the bunk bed boards and ladder boards, apply a primer to the surfaces of these boards, and allow it to dry. Finally, apply a coat of paint, stain, or sealer, and let it dry. You may need to open a window in the room while the finish is drying to allow paint or sealer fumes to be replaced with fresh air.
