Building A Stud Wall In Your Home
Tackling the project for building a stud wall is not a tough job if you know what you are doing. In fact, the task is one of the simplest construction projects and with a little bit of knowledge, the right material and tools, the task can be completed in no time at all. Here’s what to do.
Materials Needed:
•2 x 4s
•2 X 2s or 2 X 3s
•Glue
•Drill with bits
•Fluted nails
•A sledgehammer
•Level
•Insulation
•Sheetrock and tape
•Electrical wiring and supplies
Step 1 – Measurements
Measure the length and height of the desired wall so you can determine the amount of lumber to buy keeping in mind the layout calls for studs placed at every 16 inches. Make sure to buy pressure treated lumber. First rate lumber is important for the wall stability so do not scrimp buying wood.
Step 2 – Floor Length
Begin by securing 2 X 4s the length of the wall directly to the floor by first applying glue. Make sure to use the type that works well with both concrete and wood. This length of wood will act as the base plate.
Step 3 – Stud Holes
At 16 inch intervals, drill pilot holes through the base plate into the floor below. Make sure to use a masonry bit if drilling into concrete. Drive three-inch fluted nails into each hole using a sledgehammer.
Step 4 – Stud Installation
Anchor the wall by placing a 2 X 2 or 2 X 3 to the adjoining wall first placing a line of liquid nail on the wall and then attach the wood. Using a level, make sure it is straight before drilling a hole where you will pound a three-inch fluted nail with a sledgehammer. Install all vertical studs making sure each is 16 inches from the next.
Step 5 – Electric and Water
Now is the time to run any electrical wiring or water plumbing. Make sure to allow for any junction boxes and deliver wiring to the spots along the wall where any electrical outlets will be installed.
Step 6 – Insulation
If you plan to insulate the wall, roll out enough material and place this between every stud filing in the space.
Step 7 – Sheetrock
Once all framing has been completed along with the necessary wiring and plumbing, hang sheetrock to complete the roughed out wall. Make sure to mark the sheetrock where any electrical outlets or plumbing pipes will need to be located. Cut these areas out once the sheetrock has been hung.
Step 8 –Finishing
Once all sheetrock has been hung, taped and prepared for finishing, either paint or wallpaper based on your individual choice. Also, finish off any electrical outlets or plumbing exits to suit your individual taste and design.
Remember two helpful hints when tackling any hoe construction project – always take time to complete each task carefully plus remember to make at least two measurements so you will only have to cut once.
