Building A Sturdy Pier And Beam Foundation
what you'll need
- Post hole digger
- Plumb line
- Level
- Concrete blocks
- 2-by-6 lumber
- Hammer
- 8-inch nails
A pier and beam foundation offers some great advantages that a full basement does not afford. It forms a crawlspace under the home that provides easy access to many of the utilities in case repairs are needed. Also, a pier and beam foundation preempts the need for heavy machinery to dig a large foundation. Large concrete foundations need the labor of outside help and contractors, while a pier and beam foundation can be built by one or two people.
Locate Your Piers
Start by locating your piers along the outside of your building. Begin at a corner and use the post digger to dig 18-by-24-inch holes spaced every 36 inches.
Pile Blocks for Solid Foundation
The piers for your foundation are cinder blocks. Place them on their sides into the holes you dug, one of top of the other until they are at least 24 inches above ground. Continue this all the way around, making constant adjustments to ensure that they are level. You do not need any concrete or mortar as the weight of your home on top will keep them in place.
Use the level and plumb line to make sure the entire pier system is level and perfectly vertical.
Backfill Holes
Once the system is in place, begin to carefully backfill the holes. Stamp the ground solid around the piers.
Interior Piers
Now that the perimeter piers are done, you can work on the interior piers along the center of the floor plan. These can be spaced every 48 inches. Follow the same procedure as before and stack the concrete blocks until they are level with the exterior blocks.
Add Beams and Joists
Once the piers are done, you can lay the 2-by-6-inch lumber in a frame, on end, to create your joist system. They will span across the floor plan of your home, as well as frame the edges. Each joist should be at 24 inch intervals.
Once you place your home onto the pier and beam foundation it will settle a little and you can make certain adjustments. For the most part, you have a very sturdy foundation that will last many years.
