Login Error
Close
Building a Walk-In Closet Step-by-Step
by DoItYourself Staff
Not only does a walk in closet add storage space, they can also add value to your home. Making everything within your closet easily accessible, a walk-in closet is a necessity for keeping your items organized and neat. The following how-to article will walk you through the process of creating a walk in closet for your home.
Step 1-Create a Plan
Before you begin any large home improvement, you need to design a plan. Your plan should include the closet size as well as where shelves will be placed. You should also take this time to choose your materials and the location for your closet.
Step 2-Assess Your Situation
Mark the area where you intend on building the closet. Make sure that you have enough space and that all of the materials needed are present. Keep in mind any adjustments or any alterations that may crop up with time. Leave room for growth whenever possible.
Step 3-Lay the Foundation
Now you will want to lay out the foundation or the footprint of your closet, beginning the building stages of the process. Build your walk in closet according to the plans that you created earlier. Make sure that you are following the old adage, "measure twice, cut once," because measuring twice will prevent you from wasting materials. Pay attention to all of the possible safety hazards as you go. Build slowly, carefully and patiently so that you do not end up causing harm to you home or having to redo parts of the construction.
Step 4-Install Shelving
Now that the basic setup for your walk in closet is completed, you can install the necessary shelving. There are numerous kits available on the market that make this simple, and these kits are often adjustable, allowing them to suit your needs in a variety of ways. You can install a few basic shelves for essential storage, or a full closet system to meet a myriad of needs.
Step 5-Install Lighting
Finally, install a lighting fixture in your closet. Since you are dealing with a large walk in closet, choosing a fixture capable of creating a lot of light will be ideal. Track lighting is a popular option for lighting installation in a walk in closet. It would be ideal to install a switch inside the closet door so that the light can be switched on and off with ease.
Keep in mind that you do not have to do all of this alone, there is no harm in asking for help if you feel stuck or overwhelmed. Many contractors will answer questions and give advice without actually participating in the building process.
 forum activity
