Login Error
Close
Building A Wood Shed From Scratch
by DoItYourself Staff
Building your own personal wood shed from scratch is an excellent solution to store and protect outdoor items or create a workspace. Building a wood shed from scratch is a much different process than building a wood shed with a prefabricated kit. Here is a guide to building a wood shed from scratch.
Tools and Materials Needed:
•Safety Goggles
•Wood
•Hinges
•Door
•Basic Tools
•Measuring Tape
•Level
Step 1: Educate Yourself on Regulations
The first thing to do is figure out whether or not you need to get a zoning permit for building a storage shed. In most of the states, a building permit is required if your storage shed is 120 square feet or larger. Make sure that you are checking with the local zoning rules as well as a local building inspector before you complete your plans for construction.
Step 2: Choose Location
Now you'll need to choose the perfect location for your storage shed. Your shed should be built on perfectly level ground and positioned for easy access to your workspace or your garage. You should definitely avoid building your custom storage shed above pipes or underground cables, because it will make repairing them more costly.
Step 3: Choose a Shed Plan
Now you should choose the right shed plan for your needs before you go about purchasing the materials that are necessary for building your custom shed. Estimate how much room you are going to need to house your equipment or to create a workspace for yourself and any future projects that you may have. There are plenty of DIY home shed plans out there that you can use.
Step 4: Gather Materials
Now is the time to gather all of the materials that you need based on the plans that you have chosen. Make sure that you have everything you need before you get started so that you don't have to put your plans on hold.
Step 5: Build the Foundation
Now you can build your custom storage shed from the ground up. Begin by installing the decking on the floor, securing it to the ground properly with a solid foundation such as concrete.
Step 6: Build the Basic Frame
Once you have a sturdy foundation, begin to construct the frame according to your plans. Take care to plan your windows and doors ahead of time while building the frame of your storage shed.
Step 7: Create the Walls
Now you can attach lumber to the frame of your storage shed to build the walls. Make sure to accommodate for your windows and door while putting up your walls. Take care to install these elements as sturdily as possible.
Step 8: Add the Roof
Install the rafters for your storage shed's roof so that the roof can be installed. Rafters make the roof sturdier, even when using thinner shingles or roofing materials. Follow your design plans when putting the roof up, making sure that there are no leaks or holes that can prevent the shed from being waterproof.
Step 9: Finishing Touches
Paint the shed or use a sealant to finish it off. Make sure that everything is sturdy and waterproof before you finish up, so that you do not end up losing all your work to the climate or weather.
 forum activity
