Building an Outdoor Kitchen Bar: Choosing the Countertops
If you are building an outdoor kitchen bar at your house, there are a number of different things that you are going to need to take into consideration. One of the most important factors to look at is the countertop of the bar. Here are a few things to consider about choosing the countertops for your outdoor kitchen bar.
Functionality
One of the most important things for you to consider when you are choosing the countertops for your outdoor kitchen bar is functionality. You want to make sure that you choose a surface that is going to be functional in an outdoor area. Just because a countertop material works in an indoor kitchen, that does not necessarily mean that it will work well outside. You need to make sure that the countertop material that you select can stand up to the weather. You also want to make sure that it is going to be easy for you to clean and that it can stand up to a lot of wear and tear.
Looks
Besides being functional, you also want a countertop surface that is going to look good as well. Most people that are building outdoor kitchen bars want them to look beautiful because they plan on entertaining there frequently. There are many different types of countertop surfaces that you could use in an outdoor application and all of them have a different look. Therefore, you are going to have to spend some time looking at all of the different materials so that you will know which one you like the best.
Cost
In many cases, you are going to be trying to complete your entire outdoor kitchen bar project within a certain budget. If this is the case, you are going to have to take into consideration how much the countertop that you have selected costs. Many times, the countertop is going to be one of the most expensive parts of the project. You do not want to devote too much money to this portion of the project because it will tie your hands in other areas of the kitchen bar.
Concrete
One of the most common materials for an outdoor kitchen bar is concrete. Concrete is definitely one of the most durable and hard materials that you can use for a countertop surface. Typically, concrete is also going to be very affordable when compared to some of the other options that you have. You can also get concrete in any color that you want so that it will match with your design scheme.
Tile
Many people elect to put tile on their outdoor countertops. Tile can provide you with a very customized look and it is also very durable. It is going to be a little more expensive than concrete and it will be more difficult to install.
Natural Stone
There are also a number of different natural stone surfaces that you could use for your outdoor countertop. Surfaces like granite and quartz are popular choices and these are typically going to be the most expensive because they come in slab form.
