Login Error
Close
Building an Outdoor Kitchen: Piping
by DoItYourself Staff
what you'll need
  • Teflon tape
  • Copper water pipes
  • Copper pipe fittings and compression rings
  • PVC sink drain kit
  • Metal pipe cutting tool
  • Channel lock pliers
  • Dual outlet valve
  • Wrench
Occasionally, you can just find no substitute: you want to install plumbing underneath the outdoor kitchen sink. Therefore, remove that pail and cloth beneath the kitchen sink and make that restoration you have been postponing for way too long. Setting up plumbing beneath the kitchen drain is often a task that many skilled DIY property owners are capable of doing with a couple of helpful suggestions.
Step 1 - Clear and Clean up the Kitchen Cupboard
Clean up the kitchen cupboard beneath the sink to start with. Get rid of all things kept in the cupboard so that you get space to do the job. Close the water connection to the kitchen area plumbing, normally situated beneath the sink. Should there be no turn-off control device, you might have to close the water supply to the entire dwelling while carrying out the water pipe maintenance. Take away the kitchen cupboard doors when possible; this gives extra space for a person to work. Put a glowing flashlight or alternatively a transportable light source beneath the cupboard to help you instantly see your efforts.
Step 2 - Measure and Cut the Required Pipe Length
Slash the copper water pipe using a pipe cutting tool. The warm water pipe is usually a 1 centimeter pipe, except if you own an aged house. This suggests the exterior size of the water pipe is 1 centimeter while the interior of the water pipe is 1/2 centimeter. Calculate the span of water pipe you require and tag it using a marker. Put the pipe cutting tool at the tag and rotate the cutting tool round the water pipe. Firmly grip the cutting tool as you shift it round the water pipe to obtain an even cut. It is not advised that you employ a hacksaw; the hacksaw may result in burrs around the side, which could cause your kitchen water pipe to drip.
Step 3 - Fit Compression Rings
Slip a standard compression ring over the water pipe; it comes with the compression protection connected to the nut. It's going to be a good fit, but nevertheless, gently tap it over until it glides in as deep as possible. Push the hollow fitting lower and as deep as possible onto the water pipe. After that, yank the protection backwards up to the connection and fasten it (this process is comparable to linking a hose pipe). Be sure you fasten it using a wrench, but do not fasten it too much such that you cannot flip it. When the connection is very firm, it may sever the water pipe and produce leakages underneath the kitchen drain.
Step 4 - Install a Double Outlet Valve
Use a dual outlet control device for the copper water pipe. A particular valve outlet is made for the kitchen drain, and the second is ideal for the dish washer. However, if you do not have a dish washer, make sure you set up a dual outlet control device for long term use. Open the water tap to test for leakages.
 forum activity
