Building Dry Creek Beds
what you'll need
- Landscapers paint
- Shovel
- Landscape fabric
- Mortar
- Trowel
- Rocks
Sometimes building a dry creek bed can help cover an area in your yard that is sloped due to runoff or a drainage problem but some homeowners simply like the look of a dry creek bed and install one for aesthetic reasons.
Step 1 – Plan and Mark the Course
Plan where your dry creek bed will “flow” down your slope.
Step 2 – Hide the Dry Creek Bed
In the event there is not a drainage reason for the slope’s existence, consider hiding the “creek's” origin by placing a plant or boulder at the head of the bed before building the creek bed.
Step 3 – Directing the Water
Always make sure the runoff does not disturb a neighbor’s property or flood a street in front of or behind your home.
Step 4 – Build a Pond
If you cannot direct the water to a drainage system or to a location off your property, consider building a small pond that is fed by the creek bed when it rains. Or, direct water runoff to an area of your yard that is sandy where it will sink into the ground.
Step 5 – Creek Bed Dimensions
You need to select a depth and a width for your dry creek bed. Creek beds that appear in nature, are wider than they are deep. A good guide is to create one that has a 2:1 ratio with the width being 2 times the depth. Therefore, you could construct a dry bed creek that is 4 inches wide by 2 inches deep.
Step 6 – Digging
Using a garden shovel with a pointed tip, dig out the 2-inch depth and place the excavated dirt along the bed's edges where you will tamp it down, contouring the creek bed.
Step 7 – Fabric
Once you’ve created a trench, place landscape fabric the entire length of the trench. Make sure it covers the earth mounds made from the excavated earth on both sides of the bed. Secure the fabric in place with garden stakes. Make sure the fabric is secure before proceeding with the next step.
Step 8 – Form the Bed
If the creek bed is for the purpose of helping to improve your lawn's drainage, all of the rocks used for the bed need to be connected to form a solid base to carry water away. You need to mortar the rocks together by first applying a 2-inch layer of mortar to the fabric. Work in small sections to lay rocks on top of the layer of mortar. Repeat the process for each section, working from the top of the slope down.
After building the dry creek bed, enhance it by placing small plants along the edges.
