Login Error
Close
Building Wooden Driveway Gates In 4 Steps
by DoItYourself Staff
what you'll need
  • Treated Lumber
  • Galvanized Screws
  • Power Drill
  • Circular Saw
  • Tape Measure
  • Level
  • Post Hole Digger/Shovel
  • Sand/Gravel
  • Concrete
  • Double Sided Latch
  • Barn Door Hinges
  • Lag Bolts (if needed)
  • Masonry Bit (if needed)
Installing a wooden driveway gate is a great way to add a little elegance to your home while protecting your own privacy. How one is installed will depend on the look you want, the materials you want (wood, wrought iron, etc.) and whether or not you have a fence of some sort already attached.
This guide will be for those with a fence wanting a wooden gate, however many of the principles can be applied to other situations.
Step 1– Attaching Posts
If you have a concrete/stone fence, start with two 2x8 beams. These will be the left and right posts for the gate, so cut them to the same height as the posts of your fence. Drill holes through the 2x8 beams and into the fence posts roughly every foot using a masonry bit and attach the beams to the fence posts with lag bolts. The 2x8 beams will be used to attach the hinges and latch of your gate to your fence.
If you have a wooden fence, check the size of your posts where you want to attach the gate. If they are 6x6 or larger, they will work, however if they are smaller you will have to plant 6x6 gate posts against the fence posts, as anything smaller won’t be strong enough to hold up your gate. If you have no fence at all, make sure your gate posts are at least 6x6. Cut them to at least 1½ feet longer than the height you want; this extra will be buried. Dig your hole about 2 feet deep. Fill the first 4 to 6 inches with sand or gravel to allow water drainage. Insert your posts and fill with concrete while continually checking the level, and let the concrete dry overnight.
Step 2 – Building The Wooden Gate Frame
Build a square frame with 2x4’s to fit between your posts, leaving about half an inch on each side so it will swing freely without binding. Allow at least 4 to 6 inches of space between the ground and bottom of the frame (more if your driveway slopes upward). Place a diagonal 2x4 from one corner to the other; this extra support will keep the door from sagging over time.
Step 3 – Attach Risers
Drill vertical risers into your frame. The size is up to you, though more 2x4’s will work fine. Also, the distance between them is your choice, though you’ll need at least 1/8 of an inch to account for swelling of the wood (anything less and the swelling could damage your risers). Most wooden driveway gates don’t have more than an inch of space between risers.
Step 4 – Hang Your Gate
Attach your hinges to one side of your gate. To attach them to the post, it is best to set your gate on blocks at the height you plan to have it, screw your hinges into the posts and remove the blocks. Similarly, attach your latch (make sure its capable of opening from both sides) to the other side of the gate first, close your gate, and attach the other side of the latch to your post.
 forum activity
