Built-In Bookcase Building: Mistakes to Avoid
Built-in bookcase is simply the best being the reason is that they utilize the space in your home that would otherwise be left unused. Following are some mistakes one should avoid while building a built in bookcase-
Mistake 1 : Unplanned Start
Always make a plan before building built in bookcase. Measure all the pieces twice before cutting them. You won`t want your hard work to go in vain. Do remember to put your safety gloves and goggles on.
Mistake 2 : Improper Spacing
Before finally constructing the interior make sure they have enough room for your books according to their sizes.
Mistake 3 : Sagging
To avoid sagging, shelves must be edged with wide hardwood bands. This would give extra support to the structure of the book case.
Mistake 4 : No Room for Crown
Always remember to leave 3 inch tall toe bases for supporting the case and also leave some space for the crown.
Mistake 5 : Uneven Sanding
While sanding the wood, avoid sanding at the sides which are to be fixed to other parts. This may disturb the measurement due to uneven sanding.
