Buying And Installing Garden Windows
A garden window, also known as a window box, provides the perfect space to grow herbs or a small indoor garden. They will allow more light to enter your home as well since the windows extend beyond the walls of your house on all sides. Garden windows can be a beautiful and functional addition to your home. You will have lots of options to choose from. Here are a few things to keep in mind when you shop for and look to install garden windows in your home.
Budget Matters
Garden windows can be very pricey. Before you start shopping you want to have a maximum budget and be strict about sticking to it. Know that you will likely have to pay for installation of the windows in addition to the window purchase itself.
Placement of Garden Windows
Most people like to place garden windows in their kitchens. A garden window can be placed virtually anywhere you want to add extra light and plant growth in your home though. Most experts will say a garden window is best placed where it can achieve maximum sunlight. If the side of your house stays shady, this probably won’t be the best place for your new garden window. You also want to consider what the window is going to look like on the outside of the home as well. Because of this many people will want to place the garden windows on the back or sides of their home. There are many things to consider, and just make sure you are taking your time without rushing in to a decision.
Measuring
Measuring for garden windows isn’t always as simple as it sounds. Depending on the area you are placing the window and the window itself the measurement requirements will vary. The best thing to do is to think about what kind of window you want to install first, then find out how to best measure for that particular window. This can be a process in itself because you may have to do this several times before you find a style that will work for the area you are working with.
Type of Glass
The type of glass you choose can have a big difference in the appearance and the energy efficiency of the window. A good garden window should be made with insulated glass and will be insulated where it sets in to the frame. You can save a few bucks by not using this type of window, but it can cost you more in the long run with higher utility bills. Remember that if you want quality, you will have to pay for quality.
Shop Around
If you find a window that you love, compare the prices including installation at more than one place. Just shopping around can save you quite a bit of money. You also want to check the installers reputation with the Better Business Bureau and other local consumer reporting agencies. Remember sometimes you get what you pay for.
Understand What the Prices Include
Some installers will give you an estimate for the entire project, others will give you an estimate for the window only. You want to find out if the estimate includes removing the old window and disposal, as well as caulking and other tools. These things can add up and become quite a surprise when you go to cut the final check.
