Login Error
Close
Can a drop ceiling projector mount be installed using a single stud?
by DoItYourself Staff
For a drop ceiling projector mount that uses cables or adjustable solid metal supports connected to ceiling studs, you must attach these supports to 2 ceiling studs, to achieve maximum stability. By installing a projector mount that uses 4 support cables with 2 parallel supports on opposite sides of the mount, you prevent sway and movement of the projector. Installing a drop ceiling projector mount is not a major challenge for the average homeowner with do-it-yourself skills. The key to a successful installation is creating a stable and secure base on which to attach your projector.
 forum activity
