Login Error
Close
Can a Pocket Door Track Compensate for a Warped Door?
by DoItYourself Staff
A pocket door track will not be able to fully compensate for a warped door. When you have a pocket door, you have to make sure that your door is completely straight so that it can fit back into the pocket. If it is warped, part of the door will most likely rub up against the inside frame of the pocket. Otherwise, the door might not roll properly on the track. It might continue to work for some time, but it will most likely not operate smoothly. At this point, you may want to consider replacing your door with a new version that is straight.
 forum activity
