Login Error
Close
Can a Wall Guitar Stand Damage the Guitar Neck?
by DoItYourself Staff
A wall guitar stand provides a place for storing and displaying your guitar without using up any floor space. This wall hanger has a metal plate and two moveable brackets. The brackets are adjusted left and right to the best fit the width of the instrument. The metal plate is secured to the wall with screw bolts. A guitar is a large investment and any damage to it could be costly. Be sure the wall hanger you choose for your guitar provides a secure enough place to prevent any accidental damage to your instrument.
Proper Installation
It is vital that the wall hanger holds your guitar securely in position. A wall hanger for your guitar provides an equally secure option as a floor guitar stand, however a hanging system that is improperly manufactured or installed can cause more problems. A guitar wall stand that does not adequately support the neck of the guitar can lead to warping in the guitar form. A guitar wall stand without well positioned, sturdy brackets can cause scratching on the wood of the neck of the guitar. Be sure to use only a properly installed quality wall stand to prevent any neck damage or scratching to your guitar.
 forum activity
