Login Error
Close
Can Candle Wax Removal Damage Clothing Color?
by DoItYourself Staff
You could damage the color of your clothing during the process of candle wax removal if you use a chemical cleaning solution. If you use ice or heat, however, it should not cause any damage to your clothing. The only exception to this is if you try to use an iron directly on the surface of your clothes. If you get the iron too hot, you could burn your clothing and change the color of it. If you are careful during the process, you should not have to worry about affecting the color of your clothes.
 forum activity
