Login Error
Close
Can Cold Water Be Used in a Portable Dishwasher?
by DoItYourself Staff
The use of a portable dishwasher is common for many families whose kitchens are not large enough to accommodate a larger machine. A portable dishwasher can be a blessing to the person that is assigned kitchen duties. Although, compact; many portable dishwasher can provide the same cleaning to dirty dishes as a full size dishwasher can. However, if you want your dishes to be clean properly, the only way to accomplish this task is with the use of hot water. Cold water can be used for rinsing, but it is not suggested that you use cold water for a washing session.
Why the Use of Hot Water Is Important
Using hot water to wash your dishes in a portable dishwasher is a necessity if you want to remove stuck on dirty and grease. Hot water used in conjunction with dishwashing liquid can be effective in cutting away the grease and dirt found on most dirty dishes. Cold water unfortunately has not been proven effective in the removal of these properties. Therefore, if cold water is used in a portable dishwasher it can leave your dishes plagued with grease, food and grime, thus providing cause for another washing session.
 forum activity
