Can I build an iron spiral staircase?
Yes, it is possible to build an iron spiral staircase DIY style; whether you are able to do it yourself will depend on your DIY skills. Generally, it is more difficult to build a spiral staircase out of iron as opposed to more forgiving materials, such as wood. In order to make the iron spiral staircase secure, you will need experience with welding. If you are a welding novice, it is advisable to practice on a smaller scale before jumping into a huge project like an iron spiral staircase. You will also need access to machinery that can bend iron in order to create the spiraled hand rail. Pre-fabricated staircases are also available for purchase and require only assembly and installation, and may therefore be a preferable option.
