Login Error
Close
Can I Freeze Dry Food at Home?
by DoItYourself Staff
what you'll need
  • A perforated tray. A metal mesh tray is perfect. In a pinch if you have nothing else you can use a cookie sheet but it could take longer
  • Decide what you are going to freeze dry. Apples and carrots are good to start with.
  • You are going to slice your freeze dry food choice into paper thin slices. The thinner the better.
  • You will need to be quick because some foods quickly discolour.
To freeze dry food quickly and easily you need a commercial set up, but if you have a little time and you don’t mind waiting you can actually freeze dry food at home.
While you don’t have a vacuum chamber you do have a refrigerator. You can experiment using your freezer.
The Process for Freezer Dry Food
  • Place your tray in the freezer. It should take only about 30 minutes to freeze solid.
  • Over the next week you’ll need to continue checking on your slices.
  • It takes about a week to make your freeze dry food at home, depending on your freezer and how thin your slices are.
  • Store in plastic freezer bags or plastic containers that are air tight.
That's it. You're ready to enjoy the freeze dry food you made at home.
 forum activity
