Can Using a Gutter Cleaning Vacuum Damage Your Gutter?
A gutter cleaning vacuum is made specifically for cleaning out leaves and other debris from your gutters. You will need to be careful when vacuuming the gutters, so you don't pull down on the gutter with a lot of pressure, which may cause the gutter to come loose. Be sure to use an extension if your gutters are high up, to alleviate this issue. There will be no harm caused by the vacuuming itself. It is a fast, and easy method for cleaning gutters.
