Login Error
Close
Can you get electrocuted by an electric sub panel?
by DoItYourself Staff
A sub panel is a small electrical panel that is used to get the electrical power from a main power service to another area further away. This could be something like a garage that is away from the main house and needs power. If the sub panel is wired incorrectly then it is possible to get electrocuted by the electric sub panel. If you miswired the neutral wire and the ground wire and bonded them together instead of keeping these two wires apart, then you could get electrocuted. However, under normal circumstances as long as you are careful around a sub panel, you should be safe from being electrocuted.
 forum activity
