Car Air Conditioner Repair Troubleshooting
Car air conditioner repair skills are critical during the summer, especially in heat waves. By understanding the potential for problems and learning how to rectify them, you will be in a better position to bring your car air conditioner back to full working order.
Compressor
The compressor is the part of the air conditioning unit that is necessary to help transport the refrigerant. It works by sending the refrigerant to the condensing coils, which is the beginning of the journey which eventually sees the substance reaching the evaporator. If the compressor is defective and not turning properly, cool air will not be produced to flow into the car and will make car air conditioning repair necessary. Where this is the case, the compressor will need to be replaced.
Leaks
Refrigerant is used as part of the cooling process that makes an air conditioner work. In the event that a leak causes a reduced level of refrigerant, the air conditioner will work at a reduced capacity. Check the level of refrigerant when you find that the amount of cool air being produced by the system is limited. A leak can also cause the entire system to cuts out on a regular basis as it may prompt an automatic shut-off where the pressure is low. Rectify the problem by finding and repairing the leak before topping up the level of refrigerant.
Fuses
In the event that the fuses that are in place to power the air conditioner have blown, it will prevent the entire system from working at all. In this case, car air conditioner repair will involve locating and replacing the defective fuses.
Condenser
The condenser is a component within the car that is needed to expel heat from the car. It is a necessary step after the refrigerant has been transported through the coils. The process of compressing the gas can create heat which needs to be removed. If the condenser is not operating properly, the heat that is produced can remain in the system and cause the air conditioning to become ineffective.
Clog
Car air conditioner repair can appear to be necessary when the system actually only requires cleaning. Check the vents for signs of any clogs caused by a build up of dust and debris which prevents the free flow of air into the car. Use a soft bristle brush to clean the vents. Further, the vents on the outside of the car that are used as an escape route for hot air must be kept clean so that the air is not forced back into the car. Check the vents on a regular basis.
Switch
Where the connections that link the switch with the system have come loose or are defective, car air conditioner repair will be required to replace the wires or fix this disconnection. Similarly, the wiring that serves the entire system will need to be checked to ensure that it does not comprise any faults. Any defective wires will need to be replaced.
