Login Error
Close
Car Dent Repair: How to Pull Out a Car Dent Without Causing Damage
by DoItYourself Staff
Car dent repair is important for handling small dents and dings that seem to happen with regularly frequency to our vehicles.  Knowing how to do it will prevent you from taking your vehicle to a body shop every time a minor accident happens, which is very time consuming and costly.
Assessing the Damage
The first thing you should do for car dents is to assess the extent of the damage. Most of them can be tapped or popped back out if the metal had not creased or crumpled. You can usually know this just by looking closely at your car. If you do not see ripples that looks like partially folded metal or bumps, you should be able to repair it yourself.
Sucking Out Dents
One of the easiest ways to do it is to use a suction device on your car dent, which can be done with the common plunger. Apply it over the dent and depress it in a slow slowly but steadily. Once all the air is out, a tight seal will be formed between the plunger and the car panel and you will be able to pull the dent out.
Tapping out Dents
For dents that are on large surfaces such as the roof or hood, you can wrap a wooden block in an old towel and place it on the side opposite the dent. Tap on the block with a rubber mallet and slowly work the dent off your car.
 forum activity
