Career Change
If you are looking to make a career change there are many factors to consider. If you have worked in your field for several years and gained seniority, it can be tough to go to an entry level position somewhere else and start from scratch.
There are times when you have reached a level at your company and you will go no further, this is the time to consider a career change.
How to Make the Career Change
Before making the leap to the career change, make sure you can handle the financial differences. Even though you are more likely to be promoted more often and make more money eventually at the other position, you have to be prepared to handle the changes that will be needed in the beginning.
You will not start off at the top, you will likely begin making less and working longer hours than in your previous job. A career change can be scary and is often difficult, you have to be prepared mentally, physically, and financially before making the career change.
