Caring for an Antique Brass Faucet
Antique brass faucet can very quickly lose its charm if not taken proper care of. Like any antique, a brass faucet also requires some attention to maintain its elegance. Now, by following only a few tips, you can maintain the antiquity and functionality of your faucet over a period of time.
Tip 1: Differentiate Brass coated faucets from Brass Faucets
Usually steel faucets are coated with brass to give the classy bronze appearance. You can check the magnetic qualities of these faucets to differentiate them from proper brass faucets. Steel, being extremely magnetic, will show positive attraction and repulsion near a magnet as opposed to brass which is not magnetic. Once assured the nature of the metal, you can follow up with rest of the tips to ensure its maintenance.
Tip 2: Remove Tarnish
Antique brass faucets can get subjected to tarnish over a period of time that can affect the look of brass. You can employ several methods to remove tarnish. Most of the methods involve simple materials that can be easily accessed in your house. Use of sandpaper should be especially discouraged for this purpose as rigorous rubbing from sandpaper can affect the metal by leaving scratch marks. Instead, anti-tarnish agents have been proposed like ketchup or vinegar that are widely accepted to be most effective. You can just apply little vinegar or ketchup on a piece of cloth and rub it on the faucet to rid it of the tarnish. Vinegar can be warmed a little to get even better results.
Tip 3: Periodic Cleaning
One of the simplest ways to elongate life of any product is cleaning the product periodically. Similarly, a brass faucet should be kept clean which may require effort that doesn’t fade over a period of time. Even the touch of your fingers can leave body oil on the faucet therefore it is recommended that you wear gloves when cleaning. Although several brass cleaners can be bought in the market, simply using a damp cloth can serve your purpose very well.
Tip 4: Polish the Faucet
You can occasionally polish the faucet. This will allow brass to maintain its shine and discourage tarnishing. Several products can be bought in the market to achieve this cause. However, you can also make a polishing paste at home by mixing similar quantities of vinegar, salt and flour.
Tip 4: Regularly Oil your Faucet
Oiling is necessary to ensure that your faucet does not harden over a period of time. Since brass looks best in its natural outlook, it is recommended that you use natural oil to smooth the faucets functionality. Use of lubricants should be discouraged for the fact that lubricants color may contrast with that of brass and its chemicals may affect the originality of brass.
Tip 5: Use the Faucet Gently
Like any antique, a brass faucet requires gentleness in usage. Over tightening the screws when closing the tap can lead to cracking over a period of time. This can result in dripping and leakage. Therefore, it is recommended that the faucet be used gently and not over-tightened in closing to ensure longer durability.
