cancel
Job type :
Zip Code :
community forums
comments
Caring for Home Office Furniture
The need to have your home office furniture in tiptop condition  is vital. Furniture that is taken care of and maintained well is not only pleasant to the eye, but also spares you effort and expense in terms of repair work and replacements.
Regardless of the material used to fabricate the furniture, you will be glad to know that caring for both home & office furniture is something that can be personally managed.
Daily Care and Maintenance
The most basic of furniture care and maintenance activities is dusting. This is quite a simple procedure that can be done the same way, regardless of the type of furniture material that you have.
For the task, you will only need a simple soft cloth. Using polishing and dusting products is good, but not a necessity. You have to ensure that no moisture is left behind, since this will result in unsightly marks.
Dealing with Environmental Factors
Your home & office furniture is affected by two main environmental elements: moisture and sunlight. There isn’t a product that can protect your furniture from these elements. Therefore, the best strategy is to avoid them in the first place.
The sun’s direct rays have a negative effect, especially on wood home office furniture. The wood is damaged through cracking and drying, which then results in visibly unattractive furniture.
On the other hand, moisture damages wood furniture by making it swell and warp. There are also possibilities of mold development when the cleaning is below par and irregular.
Your home office furniture should also be kept away from excessive heat, e.g. from a fireplace.
Taking Care of Nicks and Scratches
Nicks and scratches will definitely be visible on your wooden furniture in due time. In order to restore your wooden home & office furniture to its pristine state, you can use some sandpaper to smoothen out the voids. This can then be followed by finishing the item in your desired style. Painting or staining the furniture is sure to produce admirable results. Preempt these nicks and scratches, especially on your desk top, by using desk pads.
Caring for Leather
The first thing you should do in taking care of your furniture’s leather components is to ensure that they are completely out of the path of direct sun rays. These rays dry the leather to the point where cracks are formed. The leather then begins to disintegrate gradually.
Leather should not be cleaned using alcohol-based cleaners, because they tend to be abrasive. In their place, you can use a slightly dampened lint-free cloth. Excessive wetness on the cloth tends to leave water marks behind.
Furniture Maintenance
Maintenance is an important aspect of home office furniture care, which can be easily done. The task may be as simple as replacing a missing screw or reinforcing a weak leg. Tiny repairs are mostly ignored, but these tend to become worse with time. Therefore, they become harder or more expensive to handle.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
How to Build a Shoe Storage Bench
sponsored articles of the day
