Carpet Cleaning Made Easy
No matter how clean you try to keep your carpet, you will need a steam carpet cleaning one day – generally about once every 12 to 18 months. By keeping your carpet free of particles and dirt by using regular preventative maintenance like removing shoes and vacuuming weekly, you will lessen the frequency of steam cleaning and extend the lifespan of your carpet.
The day will come that you need to clean your carpet though, and the process can be quite simple. Follow the steps below to clean your carpet and have it looking brand new in no time.
1. Rent a Cleaner
Steam cleaners at nearly professional quality can be rented at your local hardware or grocery store. Though your regular vacuum may include a built-in carpet cleaning feature, it will not provide enough suction to properly clean your carpet. A carpet cleaner should be able to extract enough water from the carpet so that it dries in 12 hours, so find a rental unit with that power. Prolonged dampness can lead to mildew and bacteria growth in the carpet and turn your home into an unhealthy living environment.
2. Vacuum Your Carpet
It is imperative that all particles and dry soil is removed from your carpet before you begin the process. Otherwise, this debris will get pushed down and soaked by the steam, making it harder to remove and leaving the carpet looking soiled.
3. Treat Any Stains
If areas of your carpet are soiled from high traffic or any stains have not been properly removed, now is the time to take care of them. Use a carpet spot and stain remover before you begin the cleaning process. There are many natural carpet cleaning products on the market today that will remove stains without using harsh petroleum or chlorine-based solvents.
4. Clean the Carpet
Clean the carpet with the steam cleaner according to the instructions specified with the machine. Pick a non-toxic cleaner to ensure that your house does not suffer from poor indoor air quality on account of the cleaning.
5. Rinse the Carpet
Get as much shampoo out of your carpet as possible by rinsing it with hot water. Shampoo leaves a sticky residue on the carpet and any left will cause your carpet to become soiled again at an accelerated rate.
6. Let the Carpet Dry
Take the time to wait for your carpet to dry before moving furniture or walking on it. It is very important that you let it thoroughly dry so as not to promote mold or get it dirty again before it dries. You can speed the process by using several fans to move the air around the carpet, as well as using a dehumidifier to remove some of the moisture in the air.
