Login Error
Close
Carpet Stain Prevention
by DoItYourself Staff
Keep your carpets looking new and fresh by preventing carpet stains.
Stain Resistant Material
Most new carpets come with a stain resistant treatment. If your carpet doesn’t have that already, you can purchase a product like Scotch-Guard in a can and apply it yourself. While it won't prevent all stains, it will go a long way in protecting your carpet.
Vacuum
Frequent vacuuming can help reduce stains by removing dirt and debris that you may not be able to see. Dirt can have an abrasive effect like sandpaper on your carpet. Leaving it unattended can cause unsightly damage and darkening.
High Traffic Areas
Areas that have more traffic attract dirt much faster than other areas. While you can rent steam cleaners at most chain grocery stores and super centers, consider purchasing plastic carpet runners. These are clear and made of a non slick plastic or rubber material. (Some have latex undersides. Be cautious with these as they have been known to cause yellowing to lighter-colored carpets.) They generally have feet or teeth on the underside to keep them in place on top of your carpet. These are an inexpensive, preventative asset if you have pets or children.
Spills
There isn’t a lot you can do to prevent spills, but you can help control the damage caused by spills by giving them prompt attention. Clean them quickly. Never rub anything on the spill as this can cause the liquid to set in the fibers and create a stain. Instead, use a clean towel and dab up any excess moisture. Usually, some simple cold water and a towel or cloth will bring most of the spill up. If this doesn’t work, use any spray or powder stain remover. Follow the directions closely to avoid damaging the carpet.
Professional Cleaning
Even if you take good care of your carpets, it’s still a good idea to have them periodically cleaned by professionals. Once a year can be enough, or even quarterly if you have children, pets or very high traffic. When you choose a professional carpet cleaner, check the company's ratings with the Better Business Bureau. Also ask for references and consider suggestions from family and friends.
Be sure you understand which process the professional cleaner will use. Some use a dry chemical solution that requires you stay off the carpet for a certain period of time, often a number of hours. Some will use a wet process that also requires you to stay off the cleaned area for a certain amount of time. With the wet process, it can be hard to tell how clean the carpet is until after it completely dries, so familiarize yourself with the company's warranties and policies on re-cleaning if necessary.
 forum activity
