Carpet Steam Cleaning Tips
Carpet steam cleaning is perhaps the most effective method of carpet stain removal currently available. Carpet steamers can also be somewhat pricey to rent, so when you shell out the cash for a rental, you'll no doubt want to get the most for your money. This article will help you do just that by exploring the best ways to get the most out of your carpet steam cleaning.
Find the Right Carpet Steamer for the Job
This step will require you to do a little bit of research. Once you've identified the type of stains occupying your carpet, go online and seek out consumer testimonials from people who have rented or purchased carpet steamers. This is arguably the best way to find honest, unbiased reviews of any carpet steamer you're thinking of renting. Certain brands of carpet steamers may be better equipped to handle certain types of stains.
Additionally, certain brands may not be as dependable as others. Before committing to rent, you should also research which hardware or home improvement specialty shops offer the best rental rates for carpet steamers. Lastly, if you're particularly cost conscious, you may want to check online auction sites, such as eBay, to see if anyone is selling a used variation of the carpet steamer you've decided on, as this can occasionally be less expensive than renting.
Make Sure Your Carpeted Area is Clean Before Steaming it
Once you've acquired a suitable carpet steamer, you'll want to give your stain-laden carpeted area a vigorous cleaning before beginning the carpet steam cleaning process. Use your vacuum cleaner to thoroughly go over the carpet, making sure to lay waste to any remaining dust. After the floor has been properly vacuumed, you'll need to apply a pre-spray carpet cleaner to the stained areas of your carpeted area. This will ultimately aid your carpet steamer in ridding your carpet of stubborn stains.
Choose the Right Type of Carpet Shampoo for the Job
Now that you've prepped your carpeted area, you're almost ready to begin the carpet steam cleaning process. Carpet shampoo works hand-in-hand with your carpet steamer to rid your carpeted area of stains, so it's imperative that you choose the right kind of shampoo for the job. When renting your carpet steamer, be sure to specify the type of stains you are trying to combat and an employee should be able to recommend a suitable shampoo. Alternatively, you can also consult online reviews of various brands of carpet shampoo.
Make Sure Your Water is the Proper Temperature
Lastly, before proceeding to steam clean your carpet, make sure the water that goes into your carpet steamer is the right temperature. You may need to consult the device's instruction manual, but most carpet steamers require their water to be quite hot, though not boiling. In other words, very hot tap water will usually suffice.
After taking these 4 handy tips into consideration, simply fire up your carpet steamer and kiss those unsightly stains goodbye.
