Login Error
Close
Cathedral Ceiling Insulation: 4 Mistakes to Avoid
by DoItYourself Staff
Cathedral ceilings were once very popular due to their grandiose height and appearance, but these days many people realize that it is very difficult to get proper cathedral ceiling insulation installed. If you are looking for the best way to install your cathedral ceiling, then there are some mistakes which you will have to avoid in order to avoid loosing heat from all the areas of the home, If you are considering installing some cathedral ceiling insulation yourself, rather than call in a professional, then do your research, and learn the best way to prevent heat from escaping through your lofty ceiling.
1. Moisture Control
When fitting your cathedral ceiling insulation, many people don't realize that you have to install this piece of equipment with a moisture control system. A traditional method involves putting insulation into your cavity, leaving a small area at the top which allows air to circulate. This air carries moisture with it, so that you have an effective means of removing damp from behind the insulation. If you don't take some measure of control, then you are likely to end up with mold or wood rot behind the insulating fabric, and this can have serious consequences.
2. Batt Insulation
Probably the worst material to lay for moisture control is fiberglass batting. This allows movement of air, but doesn't stop the moisture from penetrating behind the insulation. If you want to insulation your cathedral ceiling properly, then you need to develop another method of keeping in heat while avoiding becoming a target for mold and damp. If you do decide to use a batting insulation on your ceiling, then avoid another mistake, and ensure that you caulk around the area thoroughly. You can also use vapor barrier paint to prevent moisture from spreading to the batts.
3. Dense Packing
Previous generations of insulation have relied upon the loose packing method to create pockets of air within the material, which was designed to provide a cushion of warm air between the heated house and the cold outside. This was a mistake, as the warm air carried water droplets into the insulation, and then cooled down sufficiently for the liquid to cling to the fabric. Instead, most builders prefer a foam spray insulation, either cellulose or urethane, which can be placed into the ceiling using a spray can, and left to dry. This density prevents air from carrying damp into the insulation. However, don't make the mistake of using a lot of foam spray insulation, as this stuff is extremely expensive. While the savings to be made from preserving the heating in your home, and avoiding water damage may pay for the foam itself, many home owners are reluctant to commit to such a cost.
4. Ventilation
You should also try and avoid committing nonsense such as having the ventilation left to allow the shingles to remain cool in summer. This has long been known to be a myth, and the roof ventilation of cathedral ceiling insulation has absolutely no affect on the temperature of your shingles or tiles.
 forum activity
