Login Error
Close
Cedar Siding Maintenance
by DoItYourself Staff
Cedar siding maintenance must be a regular task, so that you can avoid permanent damage. Cedar siding is beautiful, long-lasting and tough. However, like all other types of wood, you must be up-to-date with the care and cleaning of cedar siding. This will avoid problems such as mold, mildew, rot and water damage. Following are some of the important tips for maintenance of cedar siding.
Keep Moisture away
Moisture is the biggest damaging factor for any type of wood. You must ensure that you limit the amount of moisture and humidity that you expose the wood to. To achieve this, there are a few things you can do both inside and outside your home. Ensure that the humidity levels are kept under control. Interior humidity can also affect cedar over a long period of time. Make sure that your home is well-insulated. It's also vital to ensure that your downspouts and gutters are not clogged. Clean them regularly and ensure that water is kept away from the siding.
Look for Termites
Termites can cause grave and irreparable damage to wood. Regularly inspect the wood for any signs of termite infestations. Keep an eye for any signs of termites such as their wings, mud tubes or fecal pellets. Keep wood away from the ground, so that it has no direct contact with the soil.
Regularly Inspect the Siding for Cracks
Regularly inspect cedar siding for any signs of cracks or damage. Take prompt care of such cracks, by using an appropriate sealant or painting. This will keep moisture from entering into the wood and damaging it.
Clean Cedar Siding Regularly
Cedar siding is prone to dust and dirt accumulation, just like other types of exterior siding. You must clean it twice a year, so that it's easier to maintain. Although pressure washers are a great way of cleaning siding, they can be overwhelming to beginners. You must be very careful and only use a pressure washer on its lowest setting. Otherwise, there is a chance of damaging the wood and also of water getting underneath and causing more problems.
For general cleaning, use a soap and water solution to scrub the siding and then wash it down. If you have mold and mildew problems, you can use some bleach. A more environmentally friendly option is vinegar, which is also effective in cleaning mold. Use a soft brush to scrub the siding, and wash off the soap before it has a chance to dry out and leave marks.
Keep Pests away
Woodpeckers can peck away at your cedar siding, in their quest for food. You must keep an eye for these birds and try your best to keep them away. Hanging wind chimes near the siding can keep away the birds.
Be Regular with Staining and Painting
Most of the cedar siding you see is stained and finished. To maintain the look and appeal, you must stain the wood or apply paint as required.
 forum activity
