Ceiling Fan Wiring: 5 Installation Questions Answered
Ceiling fan wiring brings up a lot of questions for DIY enthusiasts when installing ceiling fans. If this is the first time that you have installed a ceiling fan, then you do not need to get apprehensive about doing it on your own. Below are 5 installation questions about ceiling fans that you need to know about.
Question #1 - What are the 2 controls of ceiling fans?
There are 2 types of wall controls of ceiling fans. The first type requires 2 different hot wires while the other type only requires 1 wire. The second is less expensive than the first. Choosing which type of control you should choose depends on your budget. Moreover, if you choose the single wire type, this means that you can easily control the fan without any confusion, since the controls that you are going to work with are minimal, compared to the double wire type.
Question #2 - How many wires does a ceiling fan have?
Ceiling fans mostly come with 4 wires, one of which is the ground. The colors of the wires varie but most standard wires are white, back, green and another color depending on the manufacturer. The additional color can be blue, red, black or white. The black wire is usually the hot lead that runs the fan motor, while the additional colors are the hot lead for the light kit, while the green wire serves as the ground for the assembly. The white wire is usually attached to the neutral lead from the wiring of the house. On the other hand, some houses do not have a separate ground lead (green wire) and this system uses a metal conduit instead.
Question #3 - What is the wiring if I have a remote controlled ceiling fans?
Remote controlled ceiling fans only comes with 1 hot lead, to control both light and fan, since both fixtures are controlled by an internal remote receiver.
Question #4 - What about dimmer switches?
Dimmer switches should not be used together with ceiling fans. The switch is attached to a motor, and will control the motor speed. Constant use of the dimmer switch will lead the ceiling fan motor to overheat, eventually leading to ceiling fan failure over time.
Question #5 - IS bad wiring responsible for ceiling fans catching fire or overheated motors?
In most cases, an overheated motor renders the ceiling fan broken, but it is not the immediate cause why most ceiling fans catch fire. Bad wiring is responsible for ceiling fans to catch fire. On cause of faulty wiring is backstabbed wires. These are wires that are pushed back buy the other wires, thus their connections become loose. Loose wires can cause flying sparks, and sparks can eventually cause a fire. This is the reason why it is important to always check the wiring of your ceiling fan every year, to ensure that it is still in good condition.
