cancel
Job type :
Zip Code :
community forums
comments
Ceiling Mounted Storage Installation in Three Steps
Ceiling mounted storage in a garage is a great way to free up floor space and store bulky or little used items.
Choose a Shelf Location
You’ll need to find a location on the garage ceiling where your storage rack can hang.  Make sure it is free of obstructions, such as the garage door, light fixtures or hanging bikes.
Attach to Studs
Use a stud finder (either electronic or magnetic) to locate the ceiling joists in the garage. For any garage organizer unit, it is imperative to hang heavy items from studs or joists, but with ceiling mounted storage, this step is even more important. Heavy items will quickly tear through drywall ceilings.
Use an electric drill or screwdriver to insert the mounting brackets and be sure the screws connect fully with the joists.
Adjust Shelf Height and Distribute Load
Most ceiling mounted storage in a garage allows you to adjust the depth of the shelf depending on how much clearance you have and what you’re storing on the shelves.  The adjustment is usually made with the use of a screwdriver or other simple tool.
Expect to pay from $65 for white wire ceiling mounted shelving to approximately $179 for super heavy-duty shelves that have extra capacity and can hold weights up to 150 or even 200 lbs.
member comments
Related Articles
Garage Organization - Overhead Innovations
When it comes time to organize your garage, you may suddenly find that you simply... read more
5 Garage Organization Tips to Maximize Your Storage Capacity
Many homeowners use the garage as an area for extended storage without giving too much... read more
Step Up to the Job with the Right Ladder
For every job that's out of reach there is a ladder properly suited. This article... read more
articles we like
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Plywood
Plywood is a manufactured wood made to be strong and durable and commonly used in... read more
Home Security Buyer's GuideHome Security Buyer's Guide
Find the right security system... read more
sponsored articles of the day
diy centers
