Login Error
Close
Ceiling Water Damage Repair
by DoItYourself Staff
what you'll need
  • Ladder, towels
  • Vacuum cleaner
  • Bucket
  • Putty knife
  • Screwdriver
  • Sandpaper
  • Tarpaulin
  • Joint compound
  • Kilz primer
  • Ceiling paint
Repairing ceiling water damage, whether the result of a broken pipe or torrential rainfall, is particularly important for the comfort level at your home. Regardless of whether it is made of drywall, plaster, or some other material, no ceiling can be fully protected against the vagaries of water. For this reason, it is important to know how to repair damage once it occurs. The present guide provides you with the basic guidelines that you need to follow.
Step 1 - Stop the Source of the Inflowing Water
The very first thing you should do is stop the water from leaking in. Otherwise, all the repair work will come to no good. First, fix the broken roof and replace the leaking pipe with a new one. Only then, proceed with the steps below.
 Step 2 - Dry the Ceiling above and Below
As soon as you have stopped the water source, dry the ceiling with towels, a vacuum, and/ or fans. You will have to dry the area both below and above the ceiling. In case water is still dripping down, this is an indicator that the ceiling is saturated. Dry up once again or cut out the wet portions. If the ceiling drywall has bulged out, place a bucket underneath the swollen section, take a knife or a screwdriver, and stab it. Be careful as water may pour down.
After the water damage is a fact, there is always the danger of mold forming and spreading. To avoid this additional—and rather costly—nuisance, make sure that the damaged area is completely dry before you start with the actual repairs.
Step 3 - Remove the Damaged Parts of the Ceiling
If there are any portions of the ceiling that are loose or bulging, you should scrape them away.  Use a putty knife or paint scraper to remove any flaking or chipping surface. However, you don’t have to scrape if the ceiling is preserved flat and smooth.
Step 4 - Prepare the Ceiling Surface
Use sandpaper to smooth over the ridges between the affected and clean areas. If there are big holes in the ceiling, use new sheets of drywall or plaster to repair them. Smaller holes need to be filled with joint compound only. Remove with sandpaper any resultant bumps.
Step 5 - Apply the Primer
If there are visible stains on the ceiling, apply a coating of “Kilz” primer over them. Allow to dry and, if necessary, repeat the procedure. If you skip this step and apply a coat of paint directly over the stains, they will show through.
Step 6 - Paint the Ceiling
Before you start painting, protect the floor and furniture by spreading tarpaulin over them. Once the primer has dried up, you can begin to paint. To achieve a uniform color, you may want to cover the whole ceiling.
 forum activity
